Click for HondaJet Click for Hawker Click for Bombardier Click for Westport Click for Gulfstream
Remote Controlled; Scale Jets
Discussion in 'The Ten Mile High Club' started by Jet News, Feb 27, 2018.
  1. HTMO9
    HTMO9 Senior Member
    Perfectly built and even more perfectly flown. The flight picture is absolutely realistic. Coordinated formation flying with RC planes really is the noble art of RC flying. I take my hat off for those RC pilots and the builder of this planes.
    The paint sheme shows the special farewell painting of the fighter bomber wing 34 at Memmingen, Bavaria. The military airbase is meanwhile closed and the airfiled converted into the Memmingen Allgäu Airport.
    But the builder of those perfect RC planes were cheating!!!!! These RC F-104 G planes are equipped with twin engines (most likely there were no bigger jet engines available for this project). By looking into the nozzles, you can tell.
    "Single pilot, single big engine (J-79), single big gun (M-61 Vulcan)", anything else is rubbish :p.
    Sorry, I could not resist.
    Finally applying the Gulfstream house livery on the G650 model. First flight is around the corner!
    First flight for the RAMY RC G650 model.
  4. JetForums
    JetForums Publisher/Admin
    That G650 is gorgeous!!! Given the size, I was surprised to see it is electric. Impressive performance. Love the Jeti Tx with telemetry!!
    Some swept-wing goodness in the form of the F-14!
  6. HTMO9
    HTMO9 Senior Member
    This is really a complicated RC plane. On most variable wing sweep models, you just see hard wings. Means, the wings have no movable surfaces and the plane is only steered by tailerons (compinatiom of elevator and aileron) and may be rudder(s). But this perfectly build little plane has full width flaps and spoilers, tailerons and twin full surface rudders.
    Flaps on a variable wing sweep airplane means, when the trailing edge of the wing wants to enter the wing pockets in the fuselage, the flaps need to be raised prior moving the wings backward, otherwise they will be damaged, when hitting the fuselage. And any movement of the wings will be accomodated by pretty large trim changes, as the center of gravity and center of pressure changes.
    On real variable geometry aircraft this is done by some complicated electro-hydraulic control and augmentation systems (Command and Stability Augmentation System, CSAS) as part of the primary flight control system (PFCS). On the Tornado aircraft for example, all of this is part of the fly by wire system. On the much older F-14 this is really a electro-hydraulic control system. If on the Tornado this system is degraded by any failure within the system down to mechanical mode, the aircraft is pretty hard to control. This is concidered a major emergency and the crews are pretty happy, when being safe on the ground.
    On a little RC plane this must require a pretty advanced computer assisted remote control system. I would like some of our RC specialists (Carl ?) giving some education on this systems. I have no clue how this works.
    Anyhow, congratulation to the builder and pilot of this perfect model.
    HTMO9
    While not showing any RC flying, this is a project RAMY RC has been working on for a couple of months, the Cessna Citation M2. In the video he is showing how he designs it.
    RAMYRC is building an A380 model... follow along as he progresses with the build.
    More work on the M2...
    A mashup of the RAMY RC Airbus A350 XWB RC project entire process condensed.
    Latest on the RAMY RC Citation M2 build. Working on the engines.
    Chasing an RC F-16 with a sport drone, quite interesting footage.
    Latest video on the CItation M2 from RAMY RC.
    Supercar blondie mixing up with RC jets.
    ...well this is interesting.
  16. JetForums
    Entirely too much time on his hands!
    RAMY RC wrapping the Citation M2 in the livery.
    RAMY RC doing some flying at the airfield.
    The first flight for the RAMY RC Citation M2.
    RAMY RC preparing for the Airliners Meeting 2021 with his A350 XWB RC model.
