Click for Westport Click for Cessna Click for YachtForums Click for Hawker Click for Boeing
News: Samson Sky Switchblade Flying Car Makes First Flight
  1. Switchblade Flying Car Takes First Flight
    The Switchblade Flying Car by Samson Sky has made its first flight. For those who may not know...the Switchblade is a three-wheel, street legal vehicle that you drive from your garage to a nearby local airport. Once there, the wings swing out and the tail extends in under 3 minutes. You then fly your registered aircraft directly to your destination – at up to 200-mph and 13,000-feet.
  2. Once you land at the airport, you transform your flying sports car back to driving mode – the wings safely stowed and protected – and continue to your final destination. 1,850 lbs is the estimated Max. Gross Take-Off Weight and 575 lbs payload (people, bags, fuel). The craft can hold 125 LT of fuel and in flight model it measures around 20.2-feet but reduces to 16.8-feet for ground/road driving. It is 6-feet wide and has a wingspan when deployed of 26.9-feet.
  3. If you are interested in this craft, Samson Sky suggests that it will start at around $170,000 dollars. Naturally you will require the requisite licenses to operate this craft. On the ground you will need either an automobile license or a motorcycle license. Some regulations vary from location to location. In the air you will need a private pilot license.
    Samson Sky
    915 SW Rimrock Way, Suite 201-134
    Redmond, OR 97756
    www.samsonsky.com
