Click for Dassault Click for Cessna Click for Hawker Click for Embraer Click for Bombardier
Jet Aviation Casualties
    A Korean Airbus A220-300 (former Bombardier CS300) suffered engine damage to its port side (left) engine recently. On December 27th the aircraft took off from Busan heading to Nagoya as flight KE753 with about 64 passengers onboard. Just over a quarter of an hour later indications suggested that there was an engine failure and the aircraft turned around and headed back to Busan where it landed safely. The aircraft uses the Pratt & Whiteney PW1500G powerplants. Below appears to show the damage to the blades .
    Smartwings Boeing 737 runs off runway in Moscow. Russian investigators are now probing an incident involving a departing SmartWings Boeing 737 than veered off the runway after starting its take-off run at Moscow Sheremetyevo Airport. 47 were onboard including 40 passengers and 7 crew members.
    A Being 707 cargo plane crashed near Tehran yesterday killing as many as 15. Only the flight engineer was found alive of the 16 persons onboard. The aircraft was said to have run off the runway crashing into a nearby residential neighbourhood during poor weather. AP Photo
    We are getting news that an Atlas Air Boeing 767 freighter crashed off Houston earlier this afternoon. Some reports suggest the Atlas Air cargo jet was being operated for Prime Air (Amazon) Three persons were onboard the aircraft the time and the flight left Miami enroute to George bush International Airport in Houston. The FAA and NTSB are investigating the reason for the crash.
    An Azerbaijani Executive Gulfstream G200 skidded off the runway in Moscow, Russia at the Sheremetyevo Airport. It was operated by Silk Way Business Aviation which is a company in Azerbaijan. The aircraft apparently left Baku in Azerbaijan for Russia and touchdown and clearly lost control skidding off the runway. The aircraft suffered damage as a result of leaving the runway and ploughing through the snow.
    In another incident regarding runway excursions, this Embraer ERJ145 operating for United Express as United 4933 overran the runway in Maine. In this incident four persons were injured. Amazingly the landing gear from the aircraft broke off and ended up lodged between the fuselage and the port-side engine. Photos by Crown of Maine.
    Sad news this morning...an Ethiopian Airlines Boeing 737 MAX 8 has crashed killing all 157 onboard. The aircraft is was brand new only 0.4 years old and took off from Addis Ababa (Ethiopia) heading to Nairobi (Kenya) plummeted to the ground 6 minutes after take off. The registration of the aircraft is ET-AVJ and the crash site is located about 17 NM from the airport of origin. Boeing issued a short statement; "Boeing is deeply saddened to learn of the passing of the passengers and crew on Ethiopian Airlines Flight 302, a 737 MAX 8 airplane. We extend our heartfelt sympathies to the families and loved ones of the passengers and crew on board and stand ready to support the Ethiopian Airlines team. A Boeing technical team is prepared to provide technical assistance at the request and under the direction of the U.S. National Transportation Safety Board".
    Air China has grounded all of its Boeing 737 MAX 8 aircraft until further notice. The new comes after one of Ethiopian's Boeing 737 MAX 8's crashed shortly after take off from Addis Ababa (bound for Nairobi) as ET302. The grounding of Air China's fleet of MAX 8's comes after the Civil Aviation Administration of China issued the order for all Chinese operators of the type. Cayman Airways has also grounded its MAX 8s. Indonesia's Transport Authority has also grounded MAX 8's from Lion Air and Garuda Indonesia. “In view of the fact that the two air crashes are newly delivered Boeing 737-8 aircraft, and they all occur in the take-off phase, they have certain similarities,” says the CAAC. The Ethiopian MAX 8 crash comes less than 6 months after the also fatal Lion Air MAX 8 crash.
  9. HTMO9
    HTMO9 Senior Member
    After more and more countries have grounded the B-737 Max 8, the EASA has suspended B-737 Max 8 operation for the entire EASA scope. This includes T/O, landings and overflights of any EASA country. Looks like that very soon, not many countries in the world (except the USA) will allow 737 Max8 operation anymore. Very bad news for Boeing and many airlines. More than 340 B-737 Max 8 are in operation worldwide.
    This control augmentation system (CAS) really needs an update (both hard- and software) before the B-737 Max 8 is allowed to resume operations. Safety first !!
    But one thing, I do not understand is the question, why the pilots were not able to override the the CAS. On all CAS equipped aircraft, I had a rating on and I have flown in my life, there was a quick disconnect button or lever and a quick downgrade possibility for the CAS to continue the flight in manual mode for an ASAP safe landing. No aircraft should go out of control caused by a CAS failure or control transients from any other onboard computer.
    I hope, they will find the crash recorder very soon, in order to get this problem evaluated and solved. The B-737 Max 8 is a very efficient and versatile aircraft and needs to go back to the air.
    The data and flight recorders were found as far as I know.
  11. HTMO9
    HTMO9 Senior Member
    After the FAA has grounded the US registered B-737 Max8 also and Boeing has adviced all airlines to not to fly the aircraft type until further notice, all 370 B-737 Max8 are now on the ground. Better safe than sorry!
    On request of the Ethopian Airlines and their Government, the crash and voice recorders have been send to France for evaluation by the BEA, the french authority for the evaluation of civil aeronautical accidents.
    The FAA is expecting similarities beetwen the two tragic accidents in Asia and Africa. I hope the problem can be found and solved ASAP. But I am very much conform with the opinion of the FAA, that this is not only a hard- and software problem. Airine Pilot Training might also need some adjustments. I would call that advanced aircraft handling and situational awareness training. Safe commercial civil aviation is IMHO more than gear up, flaps up and AP on.
  12. Kevin
    Kevin JF Moderator
    This is kind of chilling to read:
    https://www.seattletimes.com/busine...-max-system-implicated-in-the-lion-air-crash/
    TL;DR - Boeing pressured the FAA to speed up certification of the plane, and in turn the FAA allowed Boeing to do it's own assessment on many parts of the 737 MAX, including the MCAS. Also, some parameters that Boeing submitted to the FAA (and were approved) were then modified/increased after the certification and the FAA was not subsequently notified.
  13. HTMO9
    HTMO9 Senior Member
    This will be a very expensive proceeding for Boeing. A bunch of lawyers worldwide are already rubbing their hands for the upcomming damage claims.
    The initial evaluations of the crash recorder tapes of both accidents by the french BEA have shown almost congruent control transients and behaviours of the MCAS. IMHO it has proven, that both accidents have been caused by this MCAS.
    Kevin, Your link answers my question from above, why this control augmentation system could cause the aircraft to go out of control. No augmentation system should have so much control authority (and no manual override).
    And reading the above, lobbyism may have caused human lifes.
    Sorry, but I do not believe, that a simple software update will solve this problem. That is in my opinion a real design error.
    The B-737 Max8 is a great aircraft and in most aspects better than the Airbus 320 Neo. (faster, more range, more versatile and more flexible in interior design). But it may take some time for the airlines to regain confidence in this a/c. Lets hope the best for Boeing.
  14. Kevin
    Kevin JF Moderator
    An update today: https://www.adn.com/nation-world/20...-faces-more-hurdles-to-restore-737-max-fleet/
    As I mentioned in a discussion with @HTM09 as well as some other people elsewhere, the FAA finds themselves in as much hot water as Boeing.
  15. HTMO9
    HTMO9 Senior Member
    The biggest problem besides the very tragic loss of many lifes, is the loss of confidence in the FAA and Boeing. It took so long for the FAA and the other certifying agencies to accept each others certifications. If these accidents will cause these agreements to fail for longer periods, international aircraft sales will be hampered very much and many workers worldwide will loose their jobs plus the aviation businesses a lot of money.
    The FAA and Boeing must get their act together and work in cooperation with the other certifying authorities to solve the problems and get the B-737 Max8 in the air again. I does not help, if the FAA clears the aircraft flying again for the CONUS and the rest of the world will close their airspaces for the Max8, just because they do not trust this simple software update.
    What a mess!
    We had a so called Stability Augementation System (StabAug) on the F-4 Phantom. A very simple analog elctro-hydraulic sytem with 3 switches for roll, pitch and yaw plus a quick disconnect on the control stick. In case of a StabAug failure, the Phantom could make some strange but not violent movements. But in case of random electrical spices (generator failure or RCR failure, those movement were no fun (scary), especially during high speed low level flying. Even when pressing the quick disconnect, it could take up to 40 sec for the system to go completely offline.
    During a functional test flight at 40.000 ft with the Autopilot on, the StabAug system failed on me and the a/c went immediately out of control and into a spin. In this case the bold face emergency procedure called for the deployment of the drag chute for the out of control recovery. The F-4 recovered as advertised and I had to fly home with a deployed chute. I could land the a/c safely but my backseater had to wash his underpants after landing. Self induced stress, why did he not become a pilot in the first place :p.
    What I am saying is just, no CAS, CSAS, MCAS or any ancient StabAug system should make an aircraft unflyable. Mind over matter, period.
  16. Kevin
    Kevin JF Moderator
    Yes this was actually shocking when I found out that. That is crazy! Safety of the aircraft and souls onboard should not be optional.
  18. Kevin
    Kevin JF Moderator
    Sully pulls no punches here:
    https://www.marketwatch.com/story/c...e-faa-went-wrong-in-this-ugly-saga-2019-03-19
  20. Kevin
    Kevin JF Moderator
