Dassault First Customer Falcon 6X Arrives In Arkansas. The first Dassault Falcon 6X for the first customer has finished assembly and departed Dassault's France-based Bordeaux-Mérignac facility bound for the United States where it is to arrive at the completions facility in Little Rock, Arkansas. The aircraft bore the registration F-WZOC, of course this is the temporary registration. This particular aircraft is S/N 5, while S/N 4 is a test aircraft that will feature a finished interior to be tested under real-world scenarios.
The Falcon 6X will be a pretty large aircraft on the interior, in fact, it will boast having one of the largest aircraft cross sections of a purpose-built business jet, with 102 inch or 2.58-meters width. Cabin volume equates to 1,843 ft3. The cabin length is 40.4 feet and the height inside is 1.98-meters. The aircraft is powered by a pair of PW812D which are rated at around 13,500 lbs thrust. Top speed is projected to be Mach 0.90. It is expected that the Falcon 6X will be certified later this year. For more information: Dassault Falcon Jet Corporation Teterboro Airport 200 Riser Road Little Ferry, NJ 07643 www.dassaultfalcon.com ***
