Click for Cessna Click for Embraer Click for Westport Click for Boeing Click for HondaJet
Testing: Dassault’s ‘Falcon 2000S’ reaches flight test milestone
  1. Dassault’s New ‘Falcon 2000S’ reaches flight test milestone
    Dassault's newest aircraft, the twin-engine Falcon 2000S, has completed its first year of flight testing. As of today, the test aircraft has accumulated nearly 300 flight hours in more than 100 flights. The rigorous test flight program has demonstrated and confirmed the expected performance of the Falcon 2000S. Outfitted with inboard slats and winglets that work together to reduce landing speeds, the 2000S also features a unique autobrake system which will allow it to access shorter and more challenging runways than any other aircraft in its category.
    The first part of the test campaign included numerous maneuvers to demonstrate handling qualities, including stability, stalls, pitch, roll rates and failure mode tests, as well as takeoff with engine failure. Future portions of the campaign will evaluate VMCG (minimum control speed on ground) and VMU (take off minimum speed), as well as air inlet distortion around the engines and maximum crosswind demonstration.
    “The Falcon 2000S flies so smoothly that many pilots will want to operate it manually," said Jean-Louis Dumas, Dassault's Flight test pilot. "We've found that the aircraft handles well in all aspects of the flight envelop while offering very large safety margins."
    In later phases of the certification process, engineers will test and fine-tune the aircraft anti-ice system and verify the integration of EASy II, the next generation of Dassault proprietary, award-winning avionics suite. EASy II will include options like a Synthetic Vision System (SVS); Take Off and Go Around capability (TOGA); a Runway Awareness and Advisory System (RAAS); WAAS- LPV and RNP SAAAR; Automatic Decent Mode (ADM); XM Graphical Weather and ADS-B Out. The Falcon 2000S will also undergo trials to allow it to be certified for steep approaches such as London City Airport. Certification is anticipated for the end of the fourth quarter of 2012.
    Teterboro Airport
    200 Riser Road
    Little Ferry, NJ 07643
    www.dassaultfalcon.com
